Thread: hot tub jet
    Jun 2007
    Leander, TX
    14
    hot tub jet
    we have a new pool and spa. the spa has 6 jets. one of the jets barely blows any water or air. the builder says this is refered to as a ******* jet. says that it is the last jet in line and therefore blows less. just seems that when in spa mode and everything is being pumped back into the spa it would easily run 6 jets. does this sound normal?
    No that is not normal. It might be clogged, there might not be enough flow from the pump, it might have been plumbed wrong, etc. Any way you look at it the builder should get it working at least once or give you money back.
    Do you have any pictures of the plumbing before it got enclosed? Can you tell us what size/model of pump you have and what kind of jets are installed? With some more information we might be able to figure out what is going on.
    divnkd101's Avatar
    Mar 2007
    Pearland, TX (Houston Suburb)
    587
    MC,
    As Jason has already stated, some specs on your pool/ spa equipment will be helpful. I have 8 jets in my spa and not a one of them is any less forceful than the other. Although I have adjustable jets (can control the output from the jet) you should not have the trouble you are claiming to have. Have you at least unscrewed the cover of the one jet to make sure you have no obstructions? Keep us posted.
    MIKE
    21K Inground Custom w/ Spa (Gunite/Plaster), SWCG, Hayward Northstar, Polaris 280, Hayward Color Logics, Jandy PS-8
    Mar 2007
    Morris, IL
    477
    If you shut off or block the other jets does that one then work?
    steve
    Above Ground / 18' Round / Vinyl Liner / Sand Filter / 100K Gas Heater / Salt Added / No Nature2
    Jun 2007
    Leander, TX
    14
    i'll try blocking the other jets. i guess if it works while the others are covered , then it isn't clogged or partially blocked with something.
    Jun 2007
    Leander, TX
    14
    well, i wound up taking the jet apart myself. there was a rock in there blocking flow. the contractor is really losing steam now that the job is almost complete. getting him to come back for anything is a real task now. he still has a few things to complete before final payment though. as they say, if you want something done right, do it yourself! i shoud have built the **** pool.
