Seepage from paramount system
So, the pipes going down from the bottom of the valve, right? Can you tell where the water is coming from? I mean, from the pipe joints, or maybe the gasket up above is leaking and the water dis dribbling down there?
If I understand what you're saying (and I think I do), each pipe has an O-ring where it comes out of the main valve housing. The O-rings may be going bad. You could swap them around and see if the leaks follow them. A rebuild kit is avilable that has new O-rings and gears for the valve. I just "rebuilt" mine. It didn't work when we bought the house.....it does now!
