Butterfly, thanks for the guidance. I updated my profile to include location: Bluffton, SC very near Hilton Head. See signature below for equipment and pool info.
My pool is screen enclosed. I have a Pentair Triton II TR-60 sand filter, 4 years old. I backflush pretty regularly when I see the pressure reading getting over 16 psi. Clean reading is around 10 psi.
I never noted the originally installed reading...guessing it was around 8 psi or so. I really don't need to backflush that often since the pool is screen enclosed. I have no ladders or nooks in the pool. I pulled the light niche...it was perfectly clean, no algae or scum.
I am using an older Taylor K-2005 test kit augmented with a K-1515 FAS-DPD kit. I check chemistry every week and usually keep pH around 7.6-7.8, but it got up to 8.0 2 weeks ago so I used some dry acid to get it back to 7.5. TA is around 100, FC is currently at 12 (still coming down from the SLAM), CC is 0, CH is 275, CYA is 45, and the water is crystal clear.
I have never chemically cleaned the filter. Based on this info do you think I should chemically clean the filter or open it? Never had it open so I'm not sure of the procedure other than turn off pump and secure breaker then use the spanner wrench that came with the filter.
I could use some guidance on what to look for. I appreciate the help...you guys are all superb and this site is the best I have ever found. I use it all the time, especially the pool calculator for all my chemical treatments. Thanks!
