Results 1 to 7 of 7
Thread: shock in new pool
    Jun 2007
    Leander, TX
    14
    shock in new pool
    we had a new gunite pool installed a month or so ago. when the guy came out for start up, he put in "shock". our pool is a darker grey plaster. now the deep end has a huge white or lighter grey area. could anthing else have caused this other than the shock? thanks for any replies.
    SeanB's Avatar
    Mar 2007
    Missouri City (suburb of Houston, TX)
    2,622
    Was the pump running when he added it? Did it settle in that area?
    TFP Founder
    My Pool: 13K gal IG gunite with 7' spa, Pentair Cartridge Filter, Intellichlor IC40 SWG, Polaris 280 Cleaner, TF-100 Test Kit w/ salt test.
    During construction water often pools down to the bottom of the deep end. There might have been an acid wash towards the end that would have pooled down there. Shocking the pool with chlorine seems like the most likely cause, but it could have been acid, or any other chemical wash they used after plastering.
    It might also be a layer of plaster dust or scale. Have you tried brushing the stained area to see if the color changes at all?
    Jun 2007
    Leander, TX
    14
    the pool was brushed 5 or 6 times a day for the first three weeks or so. now it is being brushed every day. yes, the pump was on when he broadcast the shock. i was told buy the local pool supply co.that i need to use a quick dissolving shock due to the color of the plaster. is there anything that can be done at this stage to fix the problem? on bright sunny days, you can't even see the difference, but on overcast days, the whiteness really stands out.
    Arizona
    925
    Now that seems odd. Are you sure it isn't some shadowing effect from something else? Can you get a picture of it to show us?
    Buggs
    14,000 gallon, in ground, plaster, free form, play pool.
    Sta-Rite Max-E-Glass with a 1.5 hp Emerson motor
    WaterCo Micron High Rate sand filter S750 490 lb, 4883 sq ft - using ZeoBest
    In floor Polaris cleaning system
    Blue Diamond robot for those after storm days when I can't wait overnight for the in floor to clean it.
    Jun 2007
    Leander, TX
    14
    definitely not a shadowing effect. it can be seen out of the water and while underwater. i'll try to get a pic of it today.
    divnkd101's Avatar
    Mar 2007
    Pearland, TX (Houston Suburb)
    587
    MC,
    Hopefully your build was a great build and you have a good reputation with your builder. I would suggest setting up a meeting with him/her and discuss options to fix/ rectify the problem. Was the person who started up your pool from an outside company or tied to the builder? It may be necessary to have that person present as well. Good Luck and keep us posted.
    MIKE
    21K Inground Custom w/ Spa (Gunite/Plaster), SWCG, Hayward Northstar, Polaris 280, Hayward Color Logics, Jandy PS-8
