Rabbit
0
- Jul 12, 2008
- 74
I actually use 10% so I went with the 12% option. So far not a single trace of "white stuff" Hoses are still crystal clear.
On a side note. I use to fill my 55 gallon fish tank with a 1/4 inch vinyl line that I would connect to a near by faucet. The line got completed coated with "white stuff" after only a few uses. That was in my old house, the new one has soft water (at least inside). I'm very convinced it's related to calcium content in the water. Without the softener the water is about 16 ppm of calcium.
This doesn't explain why I'm not getting white stuff on my LQ...only thing I can figure is that I'm using 3/8 inch line that has less side wall friction (far less) then the 1/4 inch line. I also use to run pretty high pressures when I would fill my fish tank with the 1/4 inch stuff....again more side wall friction. My current CH is 400 just for reference.
