how do I switch from pristine blue and clean to better system
Welcome to TFP!
I recommend using chlorine rather than pristine blue. To switch to chlorine you start by getting a copper level test result. Depending on how high your copper level is you may need to replace water or use a sequestrant, or you might be able to simply start using chlorine without any conversion process.
