Thread: Auto pilot - better to run shorter or adjust power
    Northern VA
    59
    Is it better to run the Auto Pilot for a shorter period at 100% or a longer period at a lower power?
    I have the ability to do either as I am using the Intelliflo which runs for most of the day.
    Sean
    15 x 30 gunite pool with Riverflow Professional 12miles per hour flow (10HP silent ABB pump) to make the entire pool flow - Pentair Intellitouch i10 - Heat pump AquaComfort 110 - Raypak 399k Digital Gas Heater - Pool Pilot Digital SC-48 - Pentair FNS Plus 60 - Polaris 3900 Sport Cleaner on booster pump
    2 x Pentair Intelliflo pumps - one for filter (VF) and second for Venturi Pool Jets (VS) and Jandy 6 set deckjets - Pentair PG2000 Fiberoptic lighting - Automatic PoolCover (Brown) by Pool Cover Specialists
    Winter Pool Bubble by Ameri-Dome
    Jul 2007
    Brisbane, Australia
    874
    Re: Auto pilot - better to run shorter or adjust power
    longer at lower power.
    even better if you run it a bit in a morning and a bit in the afternoon
    Guest
    Quote Originally Posted by Strannik
    Ditto!
