Results 1 to 7 of 7
Thread: new Diamond Brite now has a green stain
    Feb 2008
    Ohio
    156
    Our pool finally filled 52hrs later....we just had new diamond brite put on.
    when we started everything up, a green type substance shot out of one of the returns and now we have a nice greenish stain on the new plaster i tried to brush it but, its not coming out.
    it looks like green mineral??? the green around metal pipes/fittings, i think it might be copper???
    and I on top of that....I was just checking the pump basket to make sure it didn't have extra rocks/plaster in it and I noticed a little stream of water shooting out of one of the pipes its a metal pipe (probably the same pipe that shot out the green stuff)
    looks like a old copper pipe, all the other pipes are pvc....so it must be the return pipe. its right when it comes out of the ground and its a pin size hole....how should we stop it??? just checked its still spraying
    hope everyone has a happy and safe 4th of July!!!
    chris
    30-40yr old prehistoric IG gunite 20 X 40 approx 30000gals
    now with new cool blue Diamond Brite and blue waterline tile (looking good for 40yr old pool)
    new Hayward 244T sand filter, 3/4 Hayward pump, Jandy heat pump
    pool skim (love it)
    Guest
    Re: new Diamond Brite now has a green stain
    Sounds like you have an old pool with copper pipes and they have created a copper stain on your new plaster. Sounds like you need to get the plumbing checked.
    Feb 2008
    Ohio
    156
    yes old pipe....plumbing was fine before remodel
    can i get the stain out????
    chris
    pool skim (love it)
    ktdave's Avatar
    Katy, TX
    888
    Hi Chrisa,
    Sorry to hear about your problems
    I'm no metals stain expert, but there are some here on the forum (mbar in particular). Check out this thread: Ascorbic Treatment to rid Pool of metal stains
    Hope this helps and good luck to you!
    11,000 gal. gunite w/midnight blue and white pearl PebbleTec
    Intelliflo 4x160 pump
    Intellichlor IC-20 SWG
    Pentair cartridge filter 420 sq. ft.
    Mastertemp 400K BTU heater
    Legend Platinum cleaner
    Pool School
    JasonLion's Pool Calculator
    TF Test Kits
    Guest
    Quote Originally Posted by ktdave
    Hi Chrisa,
    Be careful using ascorbic acid on copper stains. It can sometimes make them worse. Try holding a vitamin c tablet on the stain. If it disappears then ascorbic acid can work. If it turns black or brown don't use it.
    Feb 2008
    Ohio
    156
    well I got almost all of it out...I did use the vit. c method. I thought I made it so much worse (it did turn brownish color and smeared around) but, I let the tablets soak on there for awhile and then brushed the area for awhile and almost all of it came out
    looks way better than it did...I guess we better look into getting the old copper pipe replaced. Luckily its not spitting out anymore copper, just did it when we started up....probably because it was sitting for 3 weeks.
    thanks for all the help!!!
    Chris
    pool skim (love it)
    Feb 2008
    Ohio
    156
    thanks waterbear...it was a bad copper pipe. So we just got that one capped off and disconnected and had a new return line (pvc) added to the deep end.
    this pool remodel is two steps forward and 3 back
    I will be so glad when all the work is finally done!
    and the rest of the stain came out with some acid....pool guys used a pvc pipe and poured alittle directly on the couple of spots i didn't get scrubbed out.
    they really should have briefed us and recommened to have that pipe replaced/capped before the pool was refilled....I guess the pool had air leaks (main drain) and now that it has been fixed and everything has the right pressure/flow, that old copper pipe couldn't handle the flow (thus the leaks appearing) oh' well, hopefully we will complete soon
    chris
    pool skim (love it)
