Results 1 to 8 of 8
Thread: GFI breaker or outlet?
    Sep 2007
    Toronto
    106
    I have a pole light standing less than 10 ft. from the pool. When the electrical inspector came, he said it needs to be GFI protected. A GFI breaker for my type of main panel costs about $200, I was thinking to connect a GFI outlet (which costs about $20) next to the panel, and then connect the pole light circuit to the "back" of the outlet which is also GFI protected. Is this OK?
    OH TWINS
    San Juan 8500 gal Fiberglass Pool, Sta-Rite Max-E 1 HP pump, Star-Rite System 3 Cartridge Filter 300 sq. ft,
    Sta-Rite Max-E 200,000 BTU gas heater, Aqua Logic SWG with P-4 panel. Goldline wireless remote control,
    3 Jandy Neverlube Valves with Goldline motorized control, iRobot Verro 500 pool cleaner
    5 Poolstar 1000 LED Lights, LED strip light at waterfall, Prozone Ozonator PZ7 with degasser column,
    Jandy Auto Waterfill, Aquamatic motorized pool cover, Poolbuster Max CC handheld vacuum.
    TizMe's Avatar
    Aug 2007
    Covington, Georgia
    920
    Re: GFI breaker or outlet?
    If the inspector will accept that, I would go with the GFI plug. Our panel is about 50 ft from the pool and all of our plugs ,are GFI that are within 10 ft of the pool.
    Les
    Don't have a pool right now. Just sharing what I have learned over the years!
    Helpful Links:
    Pool School,Pool Calculator,Cl/CYA Shock Chart,TF Test Kit
    Doing BBB and loving it!
    Apr 2008
    Central Texas
    326
    Ouch! $200 for a breaker? What brand of panel do you have? I had to replace one of the GFCI breakers in the panel on my pool house, as it wouldn't trip any more. (Everyone does know to test these, right?) A new 20 amp GFCI breaker for this GE panel cost about $36 at Home Depot. The ones to fit my Square-D main panel costs about the same. $200 is pretty harsh!
    Connecting the pole light to the load side of a GFCI breaker will protect the light circuit and provide a handy outdoor outlet. 8) Just be sure to also purchase a watertight junction box, watertight fittings and the proper conduit. You will also need an outdoor rated faceplate to cover the outlet when not in use.
    26,000 Gallon Gunnite IGP
    2 HP Challenger High Head Pump
    60sf Nautilus DE filter
    Polaris 280
    Mar 2007
    Texas
    444
    Quote Originally Posted by HarryH3
    At that price I would almost have to guess it is a Federal
    27' Round AG, 17,200 gallons, sand filter
    Sep 2007
    Toronto
    106
    The brand is Commander.
    I am connecting the GFI outlet next to the main panel in the basement. The cable to the pole light is buried in a conduit and it enters "somewhere" into the house, it will be almost impossible to install a GFI protection closer to the pole light. The main panel is about 75 ft. from the pole light. Is there a maximum distance between the GFI and the light?
    OH TWINS
    Apr 2008
    Central Texas
    326
    I seem to recall reading somewhere that home runs should be kept below 100 feet, so you should be OK.
    GFCI works by monitoring the current flowing through each side of the circuit and comparing the two. If there is a difference between them of 5 milliamps or above, the circuit trips off. Unlike the **** science that you see on TV, cutting the ground plug off of a power cord doesn't defeat the usefulness of a GFCI protection device.
    Polaris 280
    Mar 2007
    Texas
    444
    I do NOT recommend even thinking of doing this
    You can use a faceless GFI. It is a GFI with no outlets. You just use the load protection from the GFI to feed the light. I would just get an outdoor box with an in use cover and the faceless GFI and install the box on the pole. The cost would be about $30 total.
    Patriot Arcadia 15' round 52". Pentair Clean and Clear 100 sqft Cartridge filter, 1HP Optiflow pump, Goldline Aquatrol SWG. 2 - 4'x20' solar panels roof mounted. All rigid PVC plumbing. Resin Solar reel with 8mil Thermo-tex solar cover. 14 x 12 deck.
    Ovation 15'x24'x52'' AG. Pentair System 3 150 SQ foot cartridge filter, 1 1/2 HP pump.
