Results 1 to 7 of 7
Thread: Aqua Broom Vacuum
    Aqua Broom Vacuum
    Hello all...
    I travel frequently, and am looking for a way for my wife and/or 13 year-old son to vacuum the pool while I am away. I know that I struggle with the usual manual vacuuming process (wrestle the long hose into the pool, blow out the air, etc.)
    I have an aqua-bug, which you also need to wrestle with somewhat (plus skimming comes to a halt while the bottom looks great).
    I saw the Aqua Broom device in a pool store, and looks like it might fit the bill for me.
    I have little, if any, leaves that fall in my pool. Mostly the dirt/dead bugs are right in the middle of the pool (from the water flow around the pool), and it looks like a couple of swipes from this device should do the trick, with no hoses or anything to have to wrestle with.
    As a reference, I have a 15ft above-ground pool.
    Has anybody used the Aqua Broom?
    thanks!
    Re: Aqua Broom Vacuum
    By the way, here is the link from Sears:
    http://www.sears.com/shc/s/p_10153_1260 ... m&sLevel=0
    Mar 2007
    Knippa, Texas
    289
    Maybe I'm all wet but I wouldn't trust it. The description in combination with the pic is enough to make me wonder. The specs say *MINIMUM* operating depth is 4 ft, but the barely-bikinied gal is using it in a spa. . .
    I do admit that I haven't tried one or seen it in person, but I suspect it's junk.
    IMO, a Poolbuster is a better idea if you want a battery-powered vac that's easy to handle and use. At around $200 it's considerably more expensive, tho.
    ~Jules~
    My pool: INDOOR 13x27 rectangular fiberglass, built ~2001, BBB, TA-60 sand filter, Hayward two speed pump (1 hp/0.33 hp), 3/4 hp booster pump for solar heater
    Taylor K-2006 test
    launboy's Avatar
    Jun 2008
    S.E. Wisconsin
    582
    You could buy it, try it, and if you don't like it, return it. I think Sears is usually pretty good about returns.
    HTH,
    Adam
    18' x 42" Intex Easyset Pool, with 16' x 52" deep end in the middle. Approx. 5500 Gal.
    Hayward Power-Flo LX 1 HP, 100# Jacuzzi Brand Sand Filter(Piped underground so it looks nice) 8)
    3 - 2' x 20' Solar Pool Heater Panels(roof mounted)
    Goin' on 9 summers...NOBODY thought it would last this long.
    Buried Portable Spa sharing pumps and water with pool (Almost complete project)
    Jul 2007
    Northern NJ
    299
    I think you would be better off with the Catfish. It is a little bigger than the broom. It is made by the same company. I bought mine last year for $100 at BJ's. I have seen it online also. The battery charge lasts for aboutn 30 minutes. I moved up to the poolbuster (same company) because the catfish was just too small for my pool.
    Here are some pictures to give you an idea of the size.
    Nicole
    21' AGP (10,400g)
    Hayward PowerFlo Matrix dual-speed 1HP pump, 75 sq ft Waterway cartridge filter
    4G Liquidator, Aquabot POOL ROVER S2-40
    Sugar Land, TX
    2
    Quote Originally Posted by giulietta1
    The minimum operating depth is four inches, not four feet.
    Kentucky
    18 x 36 Vinyl Inground Rectangle
    Hayward Pump, Sand Filter and Heater
    AquaRite SWG
    CoverStar Automatic Cover
    My little Easy-Set did not come with any sort of vacuum (apparently some come with the type that go on a garden hose). So I bought an Aqua Broom at Menards yesterday because it was the last one and was on what appears to be a good sale -- I paid $40.00 for it. I made them write on the receipt that I could return it if I was not satisfied with it after trying it. Tried it tonight, not really having much hope for it. To my surprise it picked up everything on the floor of the pool I could see, including: my daughters extremely long hairs; pine needles; grass; big grit. I have not really gotten in yet to see if it picked up the really fine sand and grit that I could feel on bottom yesterday, but I know it got a lot of junk out because it looks spotless and the little filter thing had a lot in it.
    It runs on 5 D Cell batteries and for my needs is perfect -- I had been hand picking out all that junk and it was taking forever and I couldn't get a lot of the lighter stuff because when I approaced with my hand it would move. I have not other sort of vacuum (pump or garden hose) to compare it to, but for my needs it seems to work fine. The tiny pump and filter on the Easy-Set definitely would have never gotten that stuff out of there.
    POOL: Intex ultra new in 2014 (32 x 16 x 52) (seasonal; on concrete pad covered with 1.5" extruded or whatever foam insulation sheets - ugly, but comfy); added a through-wall skimmer; I add salt for feel. EQUIPMENT: Pentair SuperFlo pump (1HP, 2SPD); Pentair cartridge filter (200 sq. ft); Pentair MasterTemp natural gas heater (400,000 btu) Climate/Location: Eastern Nebraska
