Thread: Backwashing - dumps lots of sand is this normal?
    MJCP's Avatar
    Sep 2007
    Michigan
    129
    Our waste line is a flex hose leading down and away from the filter (towards the plant beds)
    Each time I backwash I notice a lot of sand is also coming out, so much so that there is now
    an obvious, sand path running away from the hose. for like 15 - 20 feet, I know that some sand would be normal, but is this "too much" and is it a sign of a problem I am missing.
    15x32 Lazy L Inground / Concrete - 20,000 US Gal 1979 build
    1.0Hp Maxiglass/ Sand Filter, 7th season with Pool
    Painted cement finish repainted 2011
    400,000 btu Pentair Master Temp NG
    Jun 2008
    Phoenix AZ
    15
    Re: Backwashing - dumps lots of sand is this normal?
    I have never had even a small amount of sand come out of my filter when backwashing, did you replace the sand recently? Did you buy the right sized sand?
    Mar 2007
    Coastalish 'down easter'
    4,160
    Did they add the recommended amount of sand? There should be a good bit of 'freeboard' between the top of the sand and the top of the filter - if that is too small (ie, they added sand to the top of the standpipe) then the extra sand is going to vacate while backwashing.
    Luv& Luk
    -Ted
    MJCP's Avatar
    Sep 2007
    Michigan
    129
    Sorry for the delay (without power for 3 days and a flooded basement - Pools is still clear though "
    The filter has done this since we bought the house,1 1/2 seasons I finally added some sand (pool sand from the pool store)
    last month to replace at least as much as I know I lost. Can't tell how high the level is inside right now but I'm guessing it is just over the half way full point.
    launboy's Avatar
    Jun 2008
    S.E. Wisconsin
    582
    I've always had a small amount of sand leave my backwash hose when I backwash. When I first turn on the pump sand comes out then after that initial dump, there is very little sand. It's always done that so I'm not concerned about it. I know the amount of sand is correct because we store the pump and filter in the garage so the sand gets dumped every year and replaced.
    HTH,
    Adam
    18' x 42" Intex Easyset Pool, with 16' x 52" deep end in the middle. Approx. 5500 Gal.
    Hayward Power-Flo LX 1 HP, 100# Jacuzzi Brand Sand Filter(Piped underground so it looks nice) 8)
    3 - 2' x 20' Solar Pool Heater Panels(roof mounted)
    Goin' on 9 summers...NOBODY thought it would last this long.
    Buried Portable Spa sharing pumps and water with pool (Almost complete project)
