I'm pretty sure it is this one but I couldnt find it on the Imperial web site.
http://surfsidepoolcompany.com/category/Ventura/c259
Russ
Russ
You can contact Garden Leisure at [email protected]
I hope this helps
The thing with replacing that is this...
Once you take the wall down, which you'll have to do to replace that if you find a new piece, you are going to find more issues and problematic spots. It's like remodeling a home... what's behind that wall and is it going to cost me big time?! Personally, that one spot doesn't look as if it's going to destroy the integrity of the pool. How does the rest of the bottom track look? If it's rusting through and disintegrating in other areas that worry you about it's stability to hold 23k gallons of water, then you should consider a replacement. How old is the pool?
