Thread: Polaris 380 question
    Jun 2008
    New Orleans, LA
    7
    Can my Polaris 380, which has it's own booster pump, be run when a 2speed 1 hp main pump is on low speed?
    Thanks
    15,000 gal fiberglass IG,Hayward S-200 sand filter, Hayward SP2607 1hp pump
    Jun 2008
    Near Tampa Florida
    17
    Re: Polaris 380 question
    To be on the safe side I'd suggest monitoring it when you first try it.
    The main thing the booster pump needs is enough flow for the booster pump to run. When you first try it you can observe whether the booster pump makes any unusual noises indicative of not having enough flow. You can also observe the return lines to your pool. Any water going through those return lines is surplus to what the booster pump needs to operate. Having some good flow is indicative that everything is fine. Finally you can observe the performance of the Polaris in climbing walls etc. Based on these observations, you should be able to judge whether it is safe to continue.
    Mike
    10K Gal IG Plaster, 1 HP Pentair WhisperFlo Pump, 100 sq ft Pentair Clean & Clear Cartridge Filter, AquaRite SWG, Paramount PCC2000 pop-up cleaner, Rheem/Raypak 266 heater, TF-100 Test Kit, SpeedStir
    Jun 2008
    New Orleans, LA
    7
    Mike,
    Thanks for your reply.
    I will keep an eye on the items you suggested.
    Dave
