MY TA is 0 and my PH is below 6.8
Dec 16, 2013
189
Cypress TX
I have a new pool (bout a wk old) which had an acid startup.
MY TA is 0 and my PH is below 6.8. I don't really notice much plaster dust when I brush.
Should I just keep brushing and let the PH get back up? Raise TA as well?
Do you have warranty concerns?
If not, you want to use borax to try and raise the pH, this will also raise the TA. If you raise the TA first, then it will get too high before you get the pH back in line.
