Pump won't run.
Aesop
Mar 10, 2014
3
Arizona
Hello all, I'm having a bit of trouble with my pool pump and I'm not sure how to proceed.
The pump is a Jandy PHPF1.5 and has a label that also says A.O.Smith Centurion.
After skimming the surface this morning, I tried to vacuum the bottom of the pool and came upon a stuck manual switch. I removed the two metal set screws/trips that activate the pump at night. The switch was locked almost in the off position, but not quite. And the timer was stuck at 3am, when i have it set to run. After removing the trips, I pulled the dial forward and set the correct time and flipped the manual switch to on. Nothing happened, no noise at all.
I checked the breaker for the house and flipped the pool pump breaker off and on again, back to the pool pump and the motor just hums and trips the breaker.
I removed the access cover for the filter on the pump's wet side and cleaned it out. I also removed the small cover on the backside of the pump to see if the pumps rotor would turn and it does.
Being that the pumps rotor spins freely(with a wrench easily, and by hand if you put some muscle to it), I'm at a loss as to what I need to check next.
I can take pictures if need be. The rest of the equipment is a mix of Jandy and Hayward.
I ordered a replacement run capacitor with the same specs(30UF, 370VAC, 50/60HZ). Old cap is an ECCOL II, PN: 628318-308. Most pool supply places i found online listed the cap for $35-45, i found the replacement on Amazon for $8.
I removed the "hump" cover that's on top of the pump motor, and tested the cap. I didn't get any resistance reading besides 0, and nothing happened when I tried to discharge the cap, I even hooked it back up and attempted to start the pump in order to energize the cap, still didn't get an arc when I tried to discharge it.
I also removed the pumps rear cap but I didn't notice a secondary capacitor anywhere.
Oh, no I'm sorry. I'm currently waiting for the new cap to arrive. The old cap was the one i didn't get any reading on. I just mentioned removing the pumps rear cover because I was looking for a second cap to test.
