Page 1 of 2 12 LastLast
Results 1 to 20 of 24
Thread: One of the largest pools I will ever see (The NBL)
    divnkd101's Avatar
    Mar 2007
    Pearland, TX (Houston Suburb)
    587
    I have been wanting to share this with everyone but just have not had the time. How many of you have seen the Movie "Armeggedon"? Well, if you remember all of the scenes where they did the training in the water, do I have a treat for you.
    I am an avid scuba diver. I have been diving for several years now. While going to school, I held a job at a dive shop where I was given the opportunity to make alot of new friends. Well, alot of those friends work for NASA at/in The NBL (Neutral Buoyancy Laboratory). I took a trip down to Clear Lake, TX. a few weeks ago to catch up with old friends at The NBL. While there, I asked for permission to post some shots of the pool and share them with all of you. When I mean pool, I mean pool. Just to give you an idea of how large this pool is, picture the Space Shuttle and then picture 4 of them in the pool at the same time. The pool holds 6.2 million gallons of water, is 202 feet long by 102 feet wide, and 40 feet deep. I am told that the pool water is receycled every 19-20 hours (I will let the pump curve folks figure that one). Anyways, I thought I would share my experience with all of you. Here are some shots. The underwater shots are of mock-ups for the International Space Station currently orbiting our Earth. Enjoy. I send a special thanks to the entire gang at the NBL (Thanks guys and girls).
    MIKE
    21K Inground Custom w/ Spa (Gunite/Plaster), SWCG, Hayward Northstar, Polaris 280, Hayward Color Logics, Jandy PS-8
    Marillion Fan's Avatar
    About a 1/2 hour from P.S.U.
    259
    Wonder if they use BBB :P
    18x33 15700 Gal Oval Above Ground
    Ranger Sand Filter w/Praher Multi Port Valve
    A.O. Smith 1.5 hp Pump
    Confer E9120 Steps
    BBB And Sparkling Clean.
    RAA's Avatar
    Mar 2007
    The Woodlands, TX
    46
    WOW
    According to BleachCalc, it would take 103 Gallons of 6% bleach to raise 1 ppm.... HAHAHA
    -Rick
    ~15k Gal IG
    Gunite/White plaster
    AquaLogic PS-8 w/SWG
    ktdave's Avatar
    Katy, TX
    888
    Very Cool! I bet it was absolutely awesome to see that up close.
    11,000 gal. gunite w/midnight blue and white pearl PebbleTec
    Intelliflo 4x160 pump
    Intellichlor IC-20 SWG
    Pentair cartridge filter 420 sq. ft.
    Mastertemp 400K BTU heater
    Legend Platinum cleaner
    Pool School
    JasonLion's Pool Calculator
    TF Test Kits
    Mar 2007
    Houston, TX
    167
    That is fantastic! I lived in Clear Lake for a while and had no idea that was there.
    Ohio
    87
    Great info and pics Thanks to you and your friends at NBL.
    24'x54" Sharkline Matrix by Wilbar International, 15,200 gallons (2015)
    Jacuzzi 75 sq ft Cartridge Filter 1 hp two speed pump
    Solar Heat with Goldline GL-235 Controller
    Intex Krystal Clear Model 28669 SWG
    TF100, SampleSizer, and Speed Stir
    SeanB's Avatar
    Mar 2007
    Missouri City (suburb of Houston, TX)
    2,622
    eh, if you've seen one giant space pool, you've seen 'em all. j/k
    Very cool. Thanks for sharing.
    TFP Founder
    My Pool: 13K gal IG gunite with 7' spa, Pentair Cartridge Filter, Intellichlor IC40 SWG, Polaris 280 Cleaner, TF-100 Test Kit w/ salt test.
    Mar 2007
    Southern NH
    39
    Wow!!
    That is very cool!!!
    18 X 40 IG Vinyl
    Pentair DE filter
    400K BTU Pentair Mini-Max Heater
    DaveNJ's Avatar
    Toms River, NJ
    520
    Hey PoolSean, how many cells and how much salt to get this pool going on SWCG. Total Control system, what size acid tank do you think. Or how many pucks do they throw in floaters.
    IG 18x36 oval vinyl, Spill over spa, Northstar 2hp-2spd, 2.5" piping, S310T 500lb Sand filter, 400k gas heater, AutoPilot SWCG
    http://www.tftestkits.net/
    New Jersey
    98
    Amazing!
    ....but no diving board......c'mon!!
    Wonder what the water temperature is....hmmmmmm
    14 x 32 Fiberglass Pool 10K gal. Hayward Pump and Sand Filter. Autopilot SWG Dig 48 and Heat Siphon 3.25sx Heat Pump.
    The Pool Calculator
    Chlorine/CYA Chart by Chemgeek
    Arizona
    925
    Wow! Wonder if they use Sand, DE or Cartridge filter.
    Buggs
    14,000 gallon, in ground, plaster, free form, play pool.
    Sta-Rite Max-E-Glass with a 1.5 hp Emerson motor
    WaterCo Micron High Rate sand filter S750 490 lb, 4883 sq ft - using ZeoBest
    In floor Polaris cleaning system
    Blue Diamond robot for those after storm days when I can't wait overnight for the in floor to clean it.
    DaveNJ's Avatar
    Toms River, NJ
    520
    pool cleaner stuck in the ladder again.
    divnkd101's Avatar
    Mar 2007
    587
    Re: Amazing!
    Quote Originally Posted by lsbarkley
    They maintain at a constant 88 degrees
    MIKE
    New Jersey
    51
    I found this picture on the Nasa Website of the Maintenance Crew adding a little Baking Soda
    to correct an Alkalinity issue.
    From_Arizona's Avatar
    Glendale, AZ
    212
    Wow - that is really cool. Thank you for sharing. I would like to spend time imprving my diving skills in that pool!!
    1980's Shasta built 30,000 gal inground diving pool. Pebble-tec interior. Pentair DE Filter. In ground pop-ups. Hayward Navigator sweeper.
    Mar 2007
    Ontario, Canada
    294
    my kreepy krawly would have problems in that pool.
    synchronized soda??
    8200 gallon 20' x 48" round vinyl frame pool,
    Intex SWCG, 12" sand filter, 1600gph pump, TF100 test kit
    SeanB's Avatar
    Mar 2007
    2,622
    Seeing those dump trucks gives you a little bit of scale to realize just how big that pool is.
    TFP Founder
    Mar 2007
    Ontario, Canada
    294
    I think those trucks were photoshopped in afterwards.
  20. Back To Top    #20
    ktdave's Avatar
    Katy, TX
    888
    Quote Originally Posted by crazycanuck
    I agree! but good humor!
    Pool School
    TF Test Kits
