Results 1 to 7 of 7
Thread: Shocking frequency
    Apr 2008
    Philadelphia - western suburbs
    34
    Shocking frequency
    This may seem like a fairly simple question, but I couldn't find an answer on any of the forums. I'm using my SWG and holding the FC around 4 without any real trouble. My CC has been less than 0.5 and typically measures 0. My pool is clear with no algae at all, and has been that way for at least six weeks. How often (if at all) do I need to shock the pool, and if I do, what FC do I raise to? I understand that I'll use bleach to raise the FC, and not use the "super chlorinate" feature on the SWG as that has been recommended in other forums. My other numbers are as follows:
    FC = 4
    CC = .5
    TA = 110
    pH = 7.5 (I'm also in the process of lowering TA through repeated use of muriatic acid, but as of this morning, the pH was back up to 7.5 from 7.2 last night)
    CYA = 80
    Salt = 3200
    Thanks!
    15,000 gallon in-ground, vinyl; PacFab Nautilus INS48 D.E. filter, Goldline Aqua Rite XL SWG, Heat Siphon SX5.0
    Oct 2007
    Valrico, FL
    540
    Re: Shocking frequency
    You don't. There is no need to shock a pool if it does not have any problems. Enjoy you lesiure!
    7,500 gal, IG pool, L shape 22' x 15', 1.5 hp pump, cartridge filter, AquaPlus SWG/Controller, Pebble-Tec liner.
    Apr 2008
    34
    That was easy, and the answer I was hoping for. Thanks!
    Butterfly's Avatar
    South Carolina
    10,045
    Well, as dschlic1 said, no need to shock if you do not have problems.
    But, to find your shock level see the "Chlorine/Cya Chart". There is also an article on "Shocking your Pool".
    These can be found in Pool School, located at top of page in sub-header. Also link in my sig.
    You're done SLAMing when:
    Apr 2008
    34
    I'm not sure how I missed that article (shocking your pool). That had all the info I needed. Sorry 'bout that. It didn't come up on the search that I did last night!
    Butterfly's Avatar
    South Carolina
    10,045
    No problem, Steve. There is a lot of information on TFP!
    Guest
    Most people with properly running SWGS never need to shock once their water parameters in in line.
