After lurking in these forums for months and learning a ton, we are finally about to break ground. Its been a lot of motivation to watch all those spectacular builds go from a patch of dirt/grass to a unique designs. Our dig is scheduled for Wednesday February 19th. As our son turns a month old. Lets just hope it comes out as great as the builds shared here. Here is what we have so far, but we are open to suggestions and ideas:
Here are the specs:
Perimeter: 168ft (Pool & Spa)
Dimensions: 20'x40' rectangular, 8'x10' sun deck, and 8'x8' negative edge glass tile spa raised 24"
Pool Depth: 3' - 6'
Volume: 29,407 gal (Pool & Spa)
Surface Area: 895 sqft
Shotcrete: 3500psi
Pool Walls & Slab Thickness: 8"
Spa Walls Thickness: 10"
Decking: 1600 sqft of Travertine French Pattern Walnut Color to include refinishing existing Terrace.
Coping: 12"x24" Travertine coping Walnut Color
Finish: Marbletite Marquis series Quarts
Pool Returns: 4 Looped
Spa Jets: 8 Jets
Skimmers: 2
Pipe Size: 2.5"
Vac Line: Yes
Valves: Jandy neverlube
Pump: Pentair 3HP VS pump
Filter: Pentair CCP 520 Cartridge filter
SWCG: Pentair IC-60
Lights: (2) Pentair Intellibrite 5G LED pool lights, (1) Pentair Intellibrite 5G LED spa light, (1) Pentair ColorCascade LED Bubbler
Blower: 2 HP
Heat Pump: Pentair Ultratemp 140K BTU
Automation: Pentair Intellitouch Load Center with i7+3 Personality kit, Pentair Screenlogic 2 controlled by iPad, (3) Pentair Valve Actuators.
Water Features: (4) Pentair MagicStream Deck Jet II's, (1) Pentair ColorCascade Bubbler on sundeck.
Additional: (2) Light posts and (2) GFCI's in the rear perimeter of the pool.
Here are the specs:
Pool Depth: 3' - 6'
Shotcrete: 3500psi
Spa Jets: 8 Jets
Skimmers: 2
Pipe Size: 2.5"
Vac Line: Yes
SWCG: Pentair IC-60
Blower: 2 HP
