weird pump issue ???
Mar 5, 2013
300
Fort Worth Texas
My pump is surging and getting a lot of air in the basket ..
When i switch the jandy valves to the SPA mode , it works perfect and in about 1-2 min. All air is out of the system , pump quiets down and runs perfectly.
Switch back to pool and air comes back ?????
Pump re plumbed new jandy 3 ways ....
Good water level ... IDK ??? Could it be a obstruction ?.
i cant figure it out "..:(
Getting air in the pump basket is a suction side leak. I'd say that it isn't the pump basket lid or the drain plugs as it doesn't leak in spa mode. I'd start running water over everything while it's leaking and see if the bubbles stop or lessen.
