Thread: filter cartridges
    Mar 2007
    Knippa, Texas
    289
    filter cartridges
    How often should one replace spa filter carts? The site where I buy them says clean at each refill and replace annually. Can I go longer by alternating two sets of carts? Would like to hear from others about their experiences.
    Thx,
    Jules
    ~Jules~
    My pool: INDOOR 13x27 rectangular fiberglass, built ~2001, BBB, TA-60 sand filter, Hayward two speed pump (1 hp/0.33 hp), 3/4 hp booster pump for solar heater
    Taylor K-2006 test
    From_Arizona's Avatar
    Glendale, AZ
    212
    I have an above ground Hot Springs spa, it is the small Solana model. We need to replace our cartridge filters this year. We have been using them since we purchased the spa in 2000. They have lasted for a while, we did have the spa drained for a total of 2 years during two house builds. This is a small spa with a large filter, so we are probably able to get longer use of them.
    1) Two filters
    2) Replace dirty with clean one
    3) place dirty one in dishwasher or clean with 1:10 ration of bleach
    4) soak in clean water overnight
    5) let air dry out of sun until it is needed for next rotation
    1980's Shasta built 30,000 gal inground diving pool. Pebble-tec interior. Pentair DE Filter. In ground pop-ups. Hayward Navigator sweeper.
    Mar 2007
    Knippa, Texas
    289
    My spa uses two filters and they are quite large, 8.5" diameter by 10.5" height. I have a set of filters I recently bought and the filters that were in it when I bought it (don't know how old they are). What is your spa's gallonage, and how often do you clean the filters?
    My spa is almost 20 years old; I bought it second-hand. It works great, but the filter compartment is inconveniently situated. The lid to the compartment is IN the tub, and when the lid is removed, the stuff trapped in the filter floats out. So I'd rather just change/clean filters upon draining, but I don't know if that's often enough.
    Thx,
    Jules
    ~Jules~
    Taylor K-2006 test
    Glendale, AZ
    212
    My spa is small, 130 gallons and the filter is easy to change. We switch the filter every 1-2months at water change. Since it is so small, we change the water more frequently than we probably need to. This is only a two person spa and the filter size is about the same size as what you describe for yours, only we use one filter.
    Mar 2007
    Knippa, Texas
    289
    Thanks for the reply! That's an interesting idea, washing the filters in the dishwasher. I'd heard of using dishwasher detergent to clean them, but not in the dishwasher itself. I'll have to see if my filters will both fit. . .
    Probably I will just go with cleaning the filters at each drain-and-refill.
    Thx,
    Jules
    ~Jules~
    Taylor K-2006 test
