Pool leak?
Dec 30, 2013
46
Warner Robins, GA
I'm currently losing about an inch of water every 8 -10 hours. Trying to determine if the loss is due to evaporation (pool water temp 49 degrees, ambient air temp anywhere from 25 to 45 degrees) or if I have a leak. No visable wet spots anywhere around the pool or at the equipment slab.
Any suggestions?
Thanks.
Barry
when I was losing that much, main drain connection in the skimmer - no tell tail sign of leak. I had two holes in skimmer one to pump, one to main drain. Can cover hole or let water line drop past the skimmer.
