Thread: How long should I run my pump?
    Jun 2008
    Nashville, TN
    30
    I am in the process of switching over to BBB from baquacrap and am wondering how long to run my pump once I am done? It is a 2hp pump and has a high and low switch. The pool store told me to run it 24/7. They also told me it was better for the pump to run constantly instead of cycling it even if I did 12 hours on and 12 hours off. I have no problem running it 24/7 but was wondering what the experts here think instead of the pool store 'experts'.
    Nashville, TN, 24' above ground 13,500 gallons, 300lb sand filter
    My Baqucrap conversion!
    starting-my-baqucrap-conversion-this-weekend-t7122.html
    Re: How long should I run my pump?
    As long as you get at least one complete turnover a day, I think that's all one really needs. However, I run mine 24/7. It keeps things that fall on top of the water (leaves, bugs, etc) from sinking to the bottom (skimmer grabs them before they sink so I don't need to vacuum as often), plus it seems like good insurance as I don't have water issues.
    It costs me about $85 per month to run my pump full time. As soon as possible I'll be buying a two speed pump and running it on low 24/7, which should drop my monthly cost to about $30 and still give me 2+ turnovers per day.
    Quote Originally Posted by Rangeball
    So I should run my pool 31326 gal / 96 gpm / 60 min per hour = 5 hrs 26 min.
    But that's assuming perfect replacement without intermediate mixing; so what kind of fudge factor should I multiply by?
    Also, is any particular time of day/night a pump should be run? Is it cheaper to run it at night?
    -Steve, Westford, MA; 31,326 gal 21' x 41' IG Imperial 1000 Series vinyl pool
    96 gpm Hayward DE-4800 filter,1.5HP,3hrs/day,$0.72/hr;TF100 test kit, Borate & Salt strips
    Quote Originally Posted by sks23cu
    At a bare minimum.
    No idea, but going for 2 turnovers is a fair and common compromise. Many report running their pump 8-12 hours per day.
    It isn't cheaper rate wise to run at night where I live, but I suppose the motor might run a bit cooler which could save some energy. You also want to make sure your run time coincides with and is adequate to thoroughly mix any chemicals you add, like bleach after sundown. Other than that, assuming good pool chemistry is maintained I think it's personal preference. Some don't want the noise at night, others don't want it when they're in the pool, etc.
    Butterfly's Avatar
    South Carolina
    10,045
    Here's some info from another thread: pump-run-time-t7099.html
    You're done SLAMing when:
