So fc is a little high , that's probably cause of the granular chlorine my dad threw in last week when we moved in, it was originals according to the first pool shop 9.5ppm , and now it's sitting at around 7.5 a week later , I've had the swg at 80% for about 4 hrs a day, but yesterday turned it back down I just over 50%
Alkalinity is a bit high according to pool school for swg , should be 60-70 but my ph is fine, so should I add acid to lower TA , and then try to increase ph by aeration?
Calcium hardness is a bit low at 200 as well, you say for swg 250-350 (plaster )
Cya @ 30 is also low , recommended 60-70 for swg
, don't get me wrong I've gone for a swim and the water feels great
, I just want to get it perfect by the numbers and bbb method , although I am open to using chemical that are already here , for example there is Muriatic acid , there is an unopened bag of calcium hardness increaser etc etc
