Hot tub flo code
Wennis
Nov 20, 2013
1
I own an Alacante III spa made by reflections. I am getting a flo error code on my control panel. I have checked for an air lock at the pump and replaced the filter. There is not a pressure switch on the heater nor can I find a flow switch anywhere. Do you know of anything else I can try or know if or where there is a flow switch or what may be causing this code. I believe that Vita spas has taken over reflections spas
I found the manual but it doesn't have any troubleshooting guide and certainly no wiring schematic. If you have a schematic you should be able to locate the flow device.
Since it's giving you a "Flo" error it almost has to have a flow sensor of some sort.
