Results 1 to 7 of 7
Thread: Mustard algae or filter issue?
    My dad's AG pool has me scratching my head. 24' round by 4.5' deep, 15,200 gal. Hayward 1hp pump and older pentair 50 gpm DE bump filter.
    We opened it late and there was a good bit of algae on the floor and walls. Shocked it, he didn't want to vacuum to waste (on a sand point) so he went through several filter changes, and eventually bought a dolphin robo-kleen which actually does a nice job.
    Anyway, pool is clear and water sparkles. He's maintaining an adequate FC level for his CYA and there is no CC. However, every morning, the floor of the pool is dirtied with a fine brownish gray dust. There are lots of trees around, but nothing seems to be pollinating. The ability to hold a FC residual and lack of CCs leads me to doubt its "mustard" algae, especially since it shows back up to the level it does overnight.
    I don't know how to calculate the head for AG pumps, but his flow is tremendous. I suspect he's exceeding his filter's max, but don't know for sure. We recently replaced his pressure gauge, and it's been reading fine, but when the flow visibly diminishes (when he was vacuuming), the pressure isn't going up much like it did in the past. So I'm left wondering if possibly he has a tear in his filter grid that is letting sediment through and back into the pool.
    I plan to have him turn his pump off overnight (he'd been running non-stop while we got things going) to test the filter. If there is less deposited on the pool the next morning, it would point to a filter problem, right?
    Thoughts?
    tagprod's Avatar
    Jul 2007
    Tomball, Texas
    489
    Re: Mustard algae or filter issue?
    I've had mustard algae in the past so I definitely know how to identify it when I see it. I've noticed that in the early stages of Mustard algae my water looks great and no CC's are showing up in my tests. I'm usually pretty good about brushing once or twice a week and I think that retards the growth. It seems to be a rather slow growing Algae that doesn't throw your pool chemistry totally out of whack. To really get rif of it, a vigilant attack of chlorine, brushing and filtering will get rid of it. Most of the time, you just trust your numbers (and I do) but like I said, the early stages of mustard algae don't show up as CC's - at least not in my pool. Are the areas in the shade where you see the mustard algae?
    Brian
    20K IG Gunite w/ raised 7ft spillover spa. 1.5 HP Hayward Northstar pump 425 sq ft Hayward cartridge filter, Colorlogic lights AquaRite SWG AquaLogic PS-8 control
    1hp pump for sheer descent
    I'm not yet convinced it's mustard algae. It's spread over the entire pool floor, not totally covered, but kind of splotchy, like deposits of sand or something. The pool floor can be totally clean at night after a few vacuum cycles, but then covered again the next morning. I wouldn't think algae could grow that fast (9-10 hours).
    I think it's the filter.
    Guest
    I suspect that you are right.
    That's comforting Like I said, I'm grasping at straws, and this is the only thing that makes any sense, although his water is crystal clear, as is his return flow.
    He's going to turn the pump off tonight after the floor is clear and the bleach is circulated. I'll post an update.
    Mar 2007
    Coastalish 'down easter'
    4,160
    Quote Originally Posted by Rangeball
    Thank you , please do that. It certainly sounds like 'blow-by' from the filter - this will confirm that
    Luv& Luk
    -Ted
    Well, you can lead a horse to water...
    He didn't turn the pump off. When he got home the floor was clear, so he just left it alone There is a possibility that his robo-kleen is causing the problem. He had a lot of stuff on the floor, and the robo moves pretty fast, stirring some of it up. It could just be stuff settling down when the vac stops, which would explain the diminishing re-deposits each morning.
    He said this morning there was less deposits, and he seems happy.
    Oh well, it's his pool. I'll quite worrying about it until he asks again.
    Thanks all.
