Aqua Rite only works on Superchlorinate
Aquatica
Platinum Supporter
512
Nassau, Bahamas
Hi Guys,
This is a strange one. The generating light and power light are on. Both green.
I have changed the board, the display PCB and the cell.
We are getting 28V.
Now when turned on the amps drop to 0. However when superchlorinate is turned on the amps go to 5. When switched back to auto amps drop to 0.
Anyone have any idea whats going on?
thanks for any insight!
Try this:
1) switch the switch to off.
2) turn percent knob to 50 percent.
3) wait 5 minutes.
4) put switch back to auto
5) within 30 seconds you should hear a click
6) when you hear the click, wait 30 seconds and then scroll through the diagnostic readings
7) post all readings
JamesW said:
Try this:
3) wait 5 minutes.
Thanks James I'll try this.
Hi James, I left it on superchlorinate the other day and just checked it today and its working now on auto. It must have needed sometime to reset or something. I cut the pump off and waited a while then turned it back on and its still working in auto mode so I guess I best not to touch it. if it aint broke dont fix it. I've seen errors like cold before and those errors reset themselves.
Thanks. B)
Gavin
