Thread: Open bottom drain?
    Jul 2007
    Mississippi Gulf Coast
    38
    Open bottom drain?
    Our pool has two bottom drains and a skimmer. Is it necessary to keep one bottom drain open? Thats the way it was set up, but the skimmer doesnt pull enough. When we close the bottom it pulls just fine. TIA Tina
    **** hath no fury like a HURRICANE!!!!
    33,000 gal. inground vinyl pool
    Re: Open bottom drain?
    Can you adjust the valve so that the bottom drain is just a little bit open and have the skimmer still work?
    Having the bottom drain on improves your circulation. It isn't critical, not all pools even have a bottom drain. But if you can get it working it is nice to have.
    Jul 2007
    38
    Its on a ball valve, so I can adjust it half way open. That wont hurt it? Thanks Tina
    ktdave's Avatar
    Katy, TX
    888
    Yes, you can do that.
    If you normally operate your pool with the drain closed and see no ill effects (cloudiness, or other symptoms of trouble), then you can probably leave it that way, but like Jason said, having the drain in even diminshed function is helpful.
    11,000 gal. gunite w/midnight blue and white pearl PebbleTec
    Intelliflo 4x160 pump
    Intellichlor IC-20 SWG
    Pentair cartridge filter 420 sq. ft.
    Mastertemp 400K BTU heater
    Legend Platinum cleaner
    Pool School
    JasonLion's Pool Calculator
    TF Test Kits
    Jul 2007
    38
    Thanks all....I have been using the pool with the drain closed to no ill effects, but I will keep it half open now.
    Tina
