Correct Filter size
paulyd
Sep 16, 2013
9
We are considering replacing our 6 yr old sand filter with a DE filter because there is a lot of excavation going on behind our house. We have been having a very difficult time keeping our pool clear. We do not have an automatic cover (and we really can't afford one.) We currently have a 1Hp pump (SF=1.25) - came as part of the Pentair SuperFlo pump. The pump has 2" connections. We have 2 - 1 1/2" return lines, 1 - 1 1/2 skimmer line, and 1 - 2" floor drain line. We also have a 5 ton Heat Siphon heat pump. We are looking for a filter with ease of use that will keep the pool clear (the sand filter just doesn't seem to be doing a good job.- especially if we get any algae or dust). We just replaced the sand 2 years ago (bought sand at Leslies). Currently we are clearing up an algae issue, and yesterday I put skimmers socks over the returns (with gum bands) Any suggestions about socks on returns...?? . Anyway, to my main question, we are looking at the Pentair Quad DE 60, but I think it might be too big. According to my calculations we should need a 36 sq. ft. filter media. Will my current pump setup be able to adequately backwash the Quad 60? Any other suggestions are welcome.
I can't really answer your question, but just for reference, I have a 26 sq ft DE filter using a 1-1/2 HP motor with 1-1/2 inch PVC piping and about 12,500 gallons of pool water (spa is 500 gal but seperate system). The system works great if I take care of the pool (i.e. no algae and I vacuum into a leaf canister). I found out years ago that back flushing only removes about 2/3rds of the DE, so I rarely backflush, but instead, remove the filter housing top, remove the grids, and hose them off into the grass. I do this 3 or 4 times a year. With a clean filter, I start out at 5 psi and I clean the filter grids when I see 10-12 psi on the guage. I use approximately 5 coffee cans (of DE volume) to re-charge the filters. Old wet DE that I hose off can be continuously hosed into the grass (until practically invisible), but I pickup and throw away any clumps.
I guess if I were buying a new DE filter system, I'd make sure that it was easy to take apart and put back together. I read that there are a few other people here that do a similar method of disassembly and hosing off the grids. You do need to be careful not to tear the grids on anything sharp. My grids typically last about 7-10 years, unless I tear one. My system is so old, that the filters are no longer made, so I won't mention a name.
No filter of any type will clear a pool of live algae. Do not expect a DE to do any better than a sand filter for that....it won't.
It is a fairly common misconception that pool water murkiness is attributable to the filter when, more often than not, it is a water chemistry (chlorine) issue.
I know that is not the question you asked but it must be considered carefully. Changing the filter type rarely has much affect on water clarity unless there is something mechanically faulty with your current filter.
I believe that sand filters are relatively simple. Ours however, seems to let some of the particulate back into the pool. You can't see it coming back in, but you can see it as it collects on the bottom of the pool. I recently replaced the gasket ( it comes attached to the diverter), as i thought this might be why some of the particulate keeps coming back into the pool. I don't get sand in the pool. Also of note is that the pressure gauge barely moves ( I just replaced it also). It continuously reads between 18 and 20 psi.
Paul, that is a very common description of dead algae collecting on the bottom of your pool....indicating that you have some live algae that exists in your pool. If that's the cause the DE filter will show no improvement. The issue is that live (invisible) algae is being partially but not completely killed and the "dead bodies" become visible on your pool floor as they accumulate in the crevices and low spots. This whole process takes place in your pool and not in the filter. I still suspect your issues are chemistry and not mechanical filtration.
That said, have you opened up the filter to see what the sand bed looks like? I doubt that there are any issues with it since you put in new sand but it might be worth doing. The sand bed should be inspected and cleaned at least biannually anyway (annual is better) so it would give you an opportunity to do that as well.
I am not suggesting chemistry issues solely as an opinion but rather based on the 9 years or so of being on these forums and seeing very similar reports....lot's of them.
A complete set of test results is often very revealing....can you post those up?
I was told by the pool store that the 3" pucks provide the "Free" chlorine. If I am only using liquid chlorine, where does the FC come from? Do borates contribute to FC, as I have not yet started adding borax? Also, I am still wondering what would cause my filter PSI to remain so stable (18-20 psi), even when vacuuming heavy algae?
:wave: Welcome to TFP!!!
You have to stay out of the pool stores ... they are full of bad advice.
chlorine = chlorine = chlorine does not matter the source. Tablets add FC and CYA and lower the pH. Liquid Chlorine adds FC and a little salt.
Ignore borates for now as you need to learn the import chemistry first (they have nothing to do with FC).
I think you should clean the sand as the link linen provided explains and then read more Pool School:
ABCs of Water Chemistry
Recommended Pool Chemicals
How to Chlorinate Your Pool
And get one of the Recommended Test Kits on order ASAP.
paulyd,
reading your last post, I would suggest you need to learn a lot more about pool water chemistry before you spend money on a new filter. It's appears you don't know if your chemistry is adequate to prevent algae and that convinces me even more that your issues are likely chemistry issues and not filtration.
Please start by reading "The ABC's of Pool Water Chemistry" up in Pool School
I'm on it. I've got the TF100 and have been getting my chemistry in line since we drained the pool a week or so ago. I have the CYA at around 40, the TA at around 100, the PH at 7.6, the FC at 20 and the CC is currently at 1.5 (but hopefully less in the a.m. as we are trying to kill the algae bloom that we let get ahead of us.) I thought I had enough FC to prevent an algae bloom, but since my cya was low ( I brought it up slowly as it can take a week to fully dissolve/register) the FC must have went too low also. Thanks for the advice. I really appreciate it.
Well, your test results indicate that you are more aware of your chemistry than seemed to be from your earlier post.
That said, because you are working on an algae bloom, that further suggests your pool murkiness is caused by algae and not a problem with filtration.
Let's go back to the beginning.....since you already had algae and your pool was (I assume) murky from that, why do you think the filter is not performing properly? I'm just a bit confused but we'll get it sorted out.
Duraleigh,
Last night I opened up the sand filter and put a garden hose in while I reached in a stirred up the sand. I did a very good job of loosening up most of the sand (even around the latterals). Then I backwashed, rinsed, and backwashed again. Then I banged on the side of the filter tank with rubber mallet. Perhaps I am expecting too much from my filter. Once the algae is dead and the CC level drops below .5, I'll give it week. If it doesn't clear up in a week, then I can safely assume that filter isn't filtering properly...?? The pool is a little better than yesterday. I tested the water again this morning (FC was 19 last night at dusk and 15 first thing this morning) and added 2 gals. of 12.5% chlorine. An hour or so after adding the chlorine, I tested again. The numbers really look good (except for the CC since we are still killing algae). The numbers are: FC=25, CC+1.5, CYA= 40, TA=110, PH=7.8, CH=340(our city water has tons of calcium, so I can't really do anything about this).
Again, thanks for your help!
Paul
After you pass the OCLT and your CC is less than 0.5 ppm, then using some pool filter DE can help getting fine particles trapped in the sand filter. See: http://www.troublefreepool.com/pool-school/add_de_to_a_sand_filter Usually this is only needed for a short time (couple of days) to speed up the cleaning process.
paulyd said:
Linen,
I tried using DE in sand filter once before, but it seemed as though the DE was coming back into pool. Is this common?
No. That would indicate a problem with either your backwash valve, the sand being channeled, or a lateral in the filter broken (although that usually shows sand back to the pool).
