Do I need to raise my TA?
triplets&quads
100
North Carolina
Intex Krystal Clear
Here are my numbers from this morning. I think my FC will fall by night time, but is it OK for to it be that high? I know I should lower my PH, but do I need to adjust the TA?
FC 6.5
TC 6.5
PH 7.8
TA 90
CYA 70
Thank you for all your help! Nancy
With your SWG adjust your output to maintain your FC between 3-5 ppm. Make small adjustments and give it a few days for the levels to stabilize each time you make an adjustment. 6.5 is a bit higher than you need but it won't hurt anything in the short run and it's certainly swimmable.
