Page 1 of 2 12 LastLast
Results 1 to 20 of 29
Thread: PUMP RUN TIME
    delfargo's Avatar
    May 2008
    some cornfield in central illinois
    86
    PUMP RUN TIME
    just curious... on average, how long do y'all run the pump? i don't like leaving the pump run while i'm at work, so i usually run it from 5:00pm till i go to bed (around 10:00) durring the week, then on the weekends i usually run it pretty much all day. just curious as to what others do.
    30' round above ground - 21000 gal. (shade ONLY in the evening),
    pentair dynamo 1.5 hp pump,
    pentair sand dollar 150 lb.sand filter,
    bbb method.
    Re: PUMP RUN TIME
    The ideal pump run time varies quite a bit from pool to pool depending on the relative sizes of the pump and pool. I run mine 8 hours a day in the summer.
    reindeerboy's Avatar
    May 2008
    Jamestown, ND
    519
    Re: PUMP RUN TIME
    I run mine 8-10 hours a day. I usualy split up the run time if possible. 6-noon and then 5 to 10 or 11. It still runs while I am at work in the am, but my daughter is home in the summer time to keep an eye on it. This is the second season I have had the pool and havent had a problem yet.
    Chad R.
    POOL SIZE: 16 x 32' Vinyl lined pool. 22,000 gallons. 8' deep. 2009 Hayward 1.5 HP Super Pump. Hayward S310S 30" 500 lb Sand filter. 1 skimmer and 2 returns. Solar Blanket.
    Pics of my pool: http://s307.photobucket.com/albums/nn312/reindeerboy/
    Jul 2007
    Summerton, SC
    39
    Re: PUMP RUN TIME
    I'm definitely a newbie at this but I have a timer on mine and it runs from 6:30 AM till 11:00 PM every day. I run my pump during the hottest part of the day with the temperatures we have been seeing in SC. So far the water is crystal clear so I may be able to back off a little more.
    Jim
    24' X 52" AGP (13,500 gal)
    Pentair Dynamo 1HP with SD-40 filter
    TF-100 test kit
    BBB and loving it
    May 2008
    Jamestown, ND
    519
    Re: PUMP RUN TIME
    I would. 16.5 hours is a long time and I would only do that if I had high traffic in my pool or am using the thing with family and friends myself.
    Chad R.
    Jun 2008
    Near Tampa Florida
    17
    Re: PUMP RUN TIME
    I run mine 3 hours a day year-round. I'm a cheapskate and don't want to buy more electricity than necessary.
    The pool is in a pool cage so little debris gets in the pool. Chlorine maintained with SWG. Water is always crystal clear and tests within all the proper ranges.
    Mike
    10K Gal IG Plaster, 1 HP Pentair WhisperFlo Pump, 100 sq ft Pentair Clean & Clear Cartridge Filter, AquaRite SWG, Paramount PCC2000 pop-up cleaner, Rheem/Raypak 266 heater, TF-100 Test Kit, SpeedStir
    Dec 2007
    Central New York
    504
    Re: PUMP RUN TIME
    I run my pump 24/7. Right now it is pumping 25 GPM at 282 watts. With these cold nights(mid 40's) and cool days, no one has been in the pool. School is still going on.
    The snakes are happy I leave the pump on. These morning there was atleast 4 wrapped around the pump. Don't know where the other 2 came from. They don't seem to be bothered by me in the pump house.
    Hotrod30
    20 X 40 foot vinyl Borates and Salt Pool
    Rolachem Chlorine Feeder
    Hayward 27 inch sand filter with 80 lbs of pea gravel
    Jacuzzi Splash Pak SP55 DE filter in parallel
    Pentair VF3050 pump
    NCFlyersFan's Avatar
    May 2008
    NE North Carolina
    116
    Re: PUMP RUN TIME
    I am currently running on a 12 on 12 off cycle. Once I get the new trip arms for my time switch, I will drop to two four hour "on" cycles per day.
    Oh yeah...I don't know how you do it. ANYTHING but snakes!
    13,000 gal AGP, Hayward X-Stream 100 sq ft cartridge, 1 HP Hayward Power-Flo Matrix Pump, all on two 6-hour on cycles per day. Baquacil to BBB convert.
    "It is necessary for us to learn from others' mistakes. You will not live long enough to make them all yourself." - Hyman G. Rickover
    summersatthelake's Avatar
    Jul 2007
    Lake Of The Ozarks, Missouri
    49
    Re: PUMP RUN TIME
    24/7 for me...new pool and electricity is cheap here
    Buggs
    14,000 gallon, in ground, plaster, free form, play pool.
    Sta-Rite Max-E-Glass with a 1.5 hp Emerson motor
    WaterCo Micron High Rate sand filter S750 490 lb, 4883 sq ft - using ZeoBest
    In floor Polaris cleaning system
    Blue Diamond robot for those after storm days when I can't wait overnight for the in floor to clean it.
    Re: PUMP RUN TIME
    Snakes? Ack!! I am not scared of them but that doesn't mean I'd enjoy finding them wrapped around my pump. I am in Central New York also. I hope your snakes aren't too close by.
    I had a mustard algae problem last year, so I ended up running the pump 24/7 for most of the summer. This year, so far, the water has been beautifully clear. I'm experimenting with the pump-run time. I've been running it overnight and turning it off in the daytime, but maybe I'll try just running it in the evenings and see how that works out. Our electricity is NOT cheap.
    12' x 24' AG Intex Metal Frame/Vinyl Liner Pool
    Intex Pump & Cartridge Filter
    7800 gal
    Aug 2007
    Pensacola
    129
    Re: PUMP RUN TIME
    I run mine 10 hours on low speed of a 2 speed pump but I do run the pump on hi speed for about a half hour of that 10 hours each morning when I add the bleach. Water is clear as can be and I often wonder if I could run it even less(but I'm not using much electricity on low speed anyway)
    24' AGP vinyl, 3/4hp Pentair 2-speed, Pentair Quad DE 60
    Pool Rover Jr.
    TF-100
    Crazycalvin's Avatar
    Mar 2008
    Irmo, South Carolina
    56
    Re: PUMP RUN TIME
    We run ours 24/7. Later, Calvin.
    15 x 26 Sharkline
    2.5 HP Dual Speed Pump
    200 Sq. Ft. cartridge filter
    Butterfly's Avatar
    South Carolina
    10,045
    Re: PUMP RUN TIME
    We usually run about 6 to 8 hours a day in the summer, broken into two runs. One morning & one evening.
    You're done SLAMing when:
    May 2008
    Jamestown, ND
    519
    Re: PUMP RUN TIME
    Does anybody swim in the pool without running the pump? Does that really matter?
    I usually like to run the pump while we are in it anyway so our pump run time is a bit more when we are swimming in it and thats mostly on the weekends while during the week its after work and we run it during that time anyway.
    I would like to know what others are doing?
    Chad R.
    Re: PUMP RUN TIME
    24/7.
    Aug 2007
    Austin, TX
    343
    Re: PUMP RUN TIME
    11 hours seem good for me at this time. I have been slowly reducing the times. electricity here is not cheap, so I am always looking to cut pump time.
    4am - 7am (3hrs): I use my solar to cool my pool during this time.
    Noon - 8pm (8hrs)
    20k Gunite/Prism Blue-Pebblesheen, Pentair Tagelus TA-100D Sand Filter, Heliocol Solar Water Heater, 2 bubblers and 2 waterfalls installed 2007, 3hp IntelliFlo VS Pump 011018 installed 2013, Aquabot Turbo T4 RC and Stenner 45MHP10 w/The Liquidator container installed 2012.
    Antigua Spa by Artesian Spas: 325 gl, 52 jets, 6 hp 2 sp & 6 hp 1 sp, Circulation System 24 Hour Whisper Pure, Ozonator, LED digital lighting, The Artesian Pillowfall installed 2007.
    Retired: 2hp Pentair Whisperflow, Legend Platinum w/booster pump, PH Adjuster
    Molson's Avatar
    Apr 2008
    Midland, Ontario
    479
    Re: PUMP RUN TIME
    I run mine from 8am to 7pm to maximize sun time on the solar panels. If I have people in the pool after 7pm, I'll leave the pump running.
    40 x 16 IG Vinyl. Goldline SWG
    160 Sq Ft Roof mounted solar array
    2014 Hydropool Serenity 5000 Hot Tub
    The Pool School- A great place to start
    Jason's Pool calculator
    Re: PUMP RUN TIME
    My pool owner's manual contains a copy of the National Swimming Pool Institute's Suggested Minimum Standards for Residential Pools Compliance by January 1, 1974.
    Section 9.1 states, "A recirculation system ... shall be provided for complete and continuous circulation of water through all parts of the pool designed to provide a minimum of two (2) turnovers in twenty-four (24) hours."
    Note that that doesn't really say you should run the system continuously, nor that you should try for two turnovers per day, just that the system should be sized that way. Codes for commercial pools say they should be run continuously.
    It's not easy to find authoritative web references for residential pools, but a few stated running the pump for one turnover per day.
    This one contained the interesting statement, "It has been proved that at least 7 complete turnover periods are needed before 99% of the pool water has actually passed through the filters."
    I'd also note that at the point in time that the pump is turned off, the water is still circulating for some time so some mixing would still be occurring. Also, even when the water becomes still there is diffusion mixing occurring.
    In the end I guess it just comes down to "guess and test", with the ecological and financial goal of finding the minimum time required. Perhaps start with one turnover per day and reduce or increase as needed. But what will indicate the "as needed"?
    -Steve, Westford, MA; 31,326 gal 21' x 41' IG Imperial 1000 Series vinyl pool
    96 gpm Hayward DE-4800 filter,1.5HP,3hrs/day,$0.72/hr;TF100 test kit, Borate & Salt strips
    Re: PUMP RUN TIME
    The normal design rules for residential pools are to size the pump and filter to have between two and three turnovers per day when running 24/7 but to actually run the pump for one turnover per day. In practice it is difficult for a pool owner to know what the actual flow rate is, unless they have a flow meter (which is rare), so the one turnover per day rule is impractical for most people.
    In any case what really matters is the cleanliness of the water. If you pay close attention to the appearance of the water you can actually see the difference between really good filtering and OK filtering. Really good filtering should leave the water sparkling and transparent. In comparison merely OK filtering gives a slightly dull appearance to the water. Based on this you can figure out a good pump run time for you pool.
    Start, when there is no algae and no problems with the chemistry, by running the pump 24/7 for a week and then carefully note the appearance of the water. Then reduce the pump run time to 12 hours a day for a week and note the appearance of the water. If the water appears identical, try a shorter pump run time. If the water has taken on a slightly dull appearance, try a longer run time. Repeat this cycle until you have narrowed in on a good pump run time. After a couple of weeks you can get a fairly good idea of what an appropriate run time is for your pool. Keep in mind that higher water temperatures will require more pump run time and lower water temperatures will require less pump run time.
  20. Back To Top    #20
    KurtV's Avatar
    Mar 2007
    SE Louisiana
    270
    Re: PUMP RUN TIME
    Jason and sks23cu have given the best answers: It's a matter of filtering the water enough to get the results you want (or to get the heating you want). I run my filter pump from 3 hours a day in the off-season up to about 6 hours a day in the summer. I also run it whenever someone is using the pool and I run it more following heavy use.
    I've also read and heard that you'll generally get better results from splitting your run time into two or more chunks each day. This seems intuitive for those chlorinating with SWGs or inline chlorinators. Outside the flatter chlorination curve, I think the idea is that organics that get into the water won't be there so long eating up chlorine.
    There's no advantage to 24/7 operation unless your water needs that much filtering to stay as clear as you want it. The argument about wear-and-tear-from-twice-or-thrice-daily-startups is bunk.
