6-way test strips
Welcome to TFP!
Pool builders and installers just aren't very good at taking care of pools. The strips are not accurate enough for more than a rough idea of your water chemistry. The drop-based kits use clear color changes and drop counts to determine levels for most water paramaters.
I have read through pool school and I appreciate it greatly. I am a severe pool novice. I was looking at the test kits but I wasn't sure if I needed the same thing for SWGs? Thanks so much. :party:
Same test kit ... your pool is still a chlorine pool.
You just may want to consider adding a salt test ... the drop based is generally more accurate than the strips.
And the TF-100 is certainly the better value.
Welcome to tfp, dolwig :wave:
The only thing you might want to add for a swg pool in addition to the tf-100 is either the aquacheck salt strips (probably good enough) or the Taylor drop based salt test (K-1766).
Always good to have an independent test for salt. One sign of the SWG getting dirty and/or starting to go bad at the ends of its life is when it starts to read lower salt levels than reality.
