PH doesn't go down?
c5-1
Jul 2, 2013
28
Hello for a while now my PH has always been at 7.8. I have been adding 14.5 muriatic acid to reduce but I never see any noticible change. I use the tf100 test kit and pool calculator to determine amount to add. For instance in Tue I tested and PH was at 7.8. I added 68ounces of muriatic acid according to pool calculator and when I tested Wednesday morning PH was still 7.8. Do I need a stonger acid? I'm I adding too little?
The amount you added should have lowered it to around 7.2 ... are you sure the pH was not above 8.2 to start? Just keep adding more until you get it to lower to where you want it.
