Intermatic T40004RT3 Timing Control Center
Jul 11, 2013
76
Puerto Rico
Hi!
I have an Intermatic T40004RT3 Timing Control Center. The unit has a Transformer built in for the low voltage lights, but the wiring from the breakers comes into the transformer and then goes out to an external Safety Volt ST-100 unit and then on to the lights.
Is this a normal setup?
Why 2 Transformers? Maybe redundancy?
I'm installing an Aqua Plus from Hayward and need to know if the Transformer inside the Intermatic is required.
Please help!
Thanks!
JGV
