waterbear said:The CH reading is NOT secondary. While it is true that you do not need the same levels of calcium in a vinyl pool you still need to know your calcium hardness. If it is high you can stil get scaling or cloudy water. If it is very low your water might have a tendency to foam. I think there is a misconception that because you do not need 200-400 ppm calcium for a vinyl pool it means you do not have to test your calcium levels. This is just not true!
Thanks for the clarification. Mine is reading 175 from the test yesterday. Is that within the acceptable range ?
Steve
