Need advice to remodel steel wall to concrete block pool
Aug 27, 2013
13
I have a 20x32 in ground steel wall which I would like to make it to a 20x40. I was thinking of doing it on cement block due to money savings. Also two of the walls are getting pushed in and it need completely new plumbing and electrical which is where I need some help. I seen a few cement block pools but nothing really helpful. I work construction on the side and a mechanic for a full time job. Any help would be nice
Filter size recommendations are based on pool volume. For the pump, a 1 hp 2 speed is likely plenty big, unless there are some high flow needs we are not aware of.
Size the SWG cell for 1.5 to 3 times the volume of your pool.
