What is the formula underlying the Pool Calculator?
gatorbrit
105
Raleigh,NC
As my pool volume doesn't change, I thought I could create a spreadsheet using the formula in the pool calculator. It would be a grid - along the top is my target FC along the side is my current FC. Each cell would have the amount that I need to add. I could then print it off and put it in my test kit box, and that way i can easily look up what I need to add.
My question then, is - what is the formula that tells you how much bleach to add to get from actual FC to your target FC?
bobodaclown said:
Is it possible to get Boric Acid added to the adding effects section at the bottom of the calculator?
Not likely, if it isn't there, the people who own it now do nothing with updating it the last I heard. Perhaps someone knows something more recent.
