New pool owner
Rwagen
14
Rockford, MI
Never owned a pool before but over the last month I have learned that the supposed experts at the pool store do not know any more than me. The previous owner used trichlor tablets and calcium hypo for shock. I am using liquid chlorine.
Test results
FC 5
CC. 0.5
PH- 7.7
TA. 170
CH. 460
CYA. 120
I am losing 3ppm chlorine daily and have significant white scale around the edge of the pool.
Here is my plan. Please correct me if I am screwing something up.
Drain 10k gallons then refill two times which should be about 60% water change. Hopefully this will get my CYA and CH back in order and make everything else easier. When I drain the water, will scrubbing with muriatic take off the white scale?
After the water change, I will test again to see what my TA is the start lowering that with the muriatic/aerate technique. Hopefully that will reduce my chlorine input.
Re. The Liquidator- From reading all of the posts about installation, I picked up that I would not need the check-valves with a below ground pool. With my pool, without the valves installed, the Liquidator allowed a bunch of air into the system when the pump shut off. After I put them in, problem solved. Question. When adjusting the flow rate, are we supposed to look at the ball in the meter, or the water level in the meter? I thought the ball would be floating in top but it isn't.
Welcome to tfp, Rwagen :wave:
This should get you to ~53 ppm cya which is good.
TA does not affect chlorine usage. It does however effect the potential for scaling. Keeping ph down around 7.2 should help with that though.
I don't have experience with the liquidator so someone else will have to answer that question.
Rwagen said:
Thank you. Reducing the CYA was what I was hoping would lower my chlorine usage. I just put that comment in the wrong section.
Well this is a little off as well. If you pool is algae free, then a higher cya level will typically reduce your chlorine consumption. The tfp recommendation of 30-50 ppm cya (we lean more towards 50 ppm cya) is to balance sun protection with reasonable maintenance FC levels and SLAM levels. You will use less FC if you go a bit higher in cya level, but you will also have to maintain a higher minimum FC level...and if you need to SLAM, then you will have to use much higher FC levels.
I would guess that you do have a low level algae growth that is using up some of your chlorine right now since at 120 ppm the sun won't use much (probably around 10%-15%). Another good reason to lower the cya, since it is likely you will need the SLAM process.
I had not realized that about my chlorine usage but that informations matches what I think I determined last night. I took chlorine measurements after dark and lost about 2ppm throughout the night. According to the pool school, that indicates that something is growing even if my water is clear. I might be keeping just ahead of it.
Now I just need to figure out when I am allowed to fill a pool in El Paso so I can do my first drain then slam the pool.
I appreciate your assistance.
Rick
