Thread: glue for light niche conduict- electrical or plumming glue??
    What glue should I use for the conduict on the light niche. I know the light niche and conduict will hold water and should be pressure tested. Should I primer and use the electrical glue or use regular pvc plumming glue? Thanks!
    chhtx
    Sep 2007
    Lafayette, Louisiana
    344
    Re: glue for light niche conduict- electrical or plumming glue??
    I use regular purple primer and pvc glue for PVC conduit. I'm not quite sure how you'll pressure test the conduit though unless the light niche has a fitting on the inside that you can plug. I used PVC glue on the male PVC threads that screw into the back of the niche.
    I'm not positive, but I think the PVC glue they sell in the electrical section is just a re-badged version of regular PVC glue.
    Fortune favors the well prepared
    The build...
    viewtopic.php?t=3974
    Freeform 24' x 38' IG gunite. 3 1/2' to 8' deep. 28,500 gallons. AutoPilot Total Control SWCG. Pentair Intelliflo VF. Pentair CCP520 cartridge filter. Colorlogic LED lights. Tahoe Blue Diamond Brite. 1200 sq ft stamped concrete deck.
    More details as they happen...
