How much CYA am I losing?
kmb997
Jun 13, 2007
111
New Orleans
I just finished cleaning up some algae. I vacuumed to waste 3-4 times and then added water to the pool each time. It has also rained a couple of times and I had to drain some water. How is the CYA level affected by all of this draining and refilling? Is the CYA affected at all?
Thanks
Pumping to waste removes CYA from the pool along with the water, while neither rain water or fill water contains any CYA, so the CYA level will be going down. How far it goes down depends on how much water you ended up removing.
