electrical question
You really should not just tap off the pump 220V box/outlet. In fact it may not have the required neutral.
If the wire is large enough, you could add a subpanel (and add a neutral wire) at the equipment and feed the pump off a 230V breaker and an outlet of the a 115V breaker. In fact, by code there should already be a 115V convienence outlet near the pool equipment.
