New Build....Nederland, TX
Being a newbie, would welcome comments on this bid concerning material and options. Only included line item cost above perimeter.
Perimeter 98 $28,250
460 sq ft CV Cartridge filter 1 $ 144
Sodium Tetra borates 1 $ 232
Ozone (prevents to break chloramines) 1 $ 580
Polaris 9300 Robotic Pool cleaner 1 $ 1,412
Flagstone coping 98 $ 2,852
Deck Coating per sq ft. 769 $ 6,982
Deck coating Topping per sq ft. 238 $ 737
Master Plumber to do 4” drains 140 $ 1,639
Measure all electric 210 $ 309
Sub Panel 1 $ 381
360 degree Ground 1 $ 462
County Gas Line 40 $ 747
250,000 BTU Heater 1 $ 2,389
Light Sealant 2 $ 139
Water Color LED Pool light 1 $ 1,970
Tanning Shelf 1 $ 387
Extra Set steps 1 $ 472
Main Skimmer Run total 2.5” pipe 40 $ 165
Additional Skimmer run 5 $ 230
Platinum Jet Pak Spa 1 $ 3,627
Inside Spa Perimeter 28 $ 1,023
Dam Wall Total 10 $ 280
Water color LED Spa Light 1 $ 741
Jandy E Pump Variable Speed 2hp 1 $ 559
Spa Plumbing all Suction 2.5” 35 $ 108
Spa Back Beam Perimeter 40 $ 560
Spa Raised 12” 1 $ 1,838
Total $ 59,200
CAVJOCK22 said:
Looks like a platinum builders quote?
Yes, Bid 3. Just received Bid #4. Will make decision tonight, any thoughts?
RE: Pool & Spa Job #13214
We are pleased to provide labor and materials to complete the following pool project.
POOL
97’ perimeter, 3’-6”- 5’ depths, 1 set of steps, 1 bench. 12” Brick Coping, Standard tile of homeowners choice Hayward Ecostar variable speed pump
Hayward 425 cartridge Filter
Hayward 400,000 BTU gas heater
3 Savi LED lights
2 – Skimmers, 6 returns in pool, 2 main drains
SPA
25’ Perimeter, 1 bench with 1 step
Cascade waterfall or scupper waterfall
8 Jets, 1 Savi LED light, 2 main drains
Brick coping and standard tile of homeowner’s choice
There will also be the removal of 4 scrubs and some trees in the corner of yard.
Start-up Kit to include pole, vacuum head, net, hose and brush.
We will do acid start up on pool and then put first chemicals in and leave you with small bucket of chlorine and 4 gallons of acid.
735sq. ft. concrete decking with spray finish, and includes spray finish on 242 sq. ft. decking. White plaster for pool and spa.
Total Price: $48,400.00 Alternate for 100% Quartz Add: $ 1,190.00
Sign papers today, went with Bid #1. Most experience of the four. Being a newbie, any changes I need?
Dimensions: 15x30 =pool & spa 10'x6' recessed steps 3 - 5- 3 depth
Structural Specs: Sidewalks, decks and patios will consist of concrete not less than 5 sacks of cement per cubic yard reinforced with #3 rebar. Pool structure will consist of pneumatic concrete (gunite) not less than 6 sacks of cement per cubic yard reinforced with #3 (3/8) rebar on 8" centers
with 4, #4 (1/2) rebar in the perimeter beam
Pool finish: Two coats White Marble
Tile: 1x1 imported frost proof
Coping (edge treatment) Bull nosed Paver
Filter and Pumps
1. 2-hp Tristar Hayward filter pump
2. 420 sq ft cart filter
3. Polaris 280 Auto Cleaner
4. 400,000 BTU Heater
5. 2-hp Tri-Star Jet Pump
6. rainbow chlorinator
7. Aqualine Programmable Control
8. Wireless Remote Controls
Pool Equipment
2 - Skimmers
1+1 - Underwater Lights White 500 watt-pool 250 watt spa
Complete set Cleaning equipment
A several points.
You can get a lift pump for your pool house waste line -- that may solve your problem but a long run is a long run.
It is interesting you bid has equipment from 3 different manufacturers, Pentair, Jandy and Hayward. Is there a reason for this? Generally, Pentair and Jandy (and I think Hayward) extend the one year warranty to three years if you purchase 3 of their products together from an authorized distributor.
The Rainbow chlorinator uses tabs. This site strongly discourages tabs except if you are on vacation. Most here strongly recommend the use of liquid chlorine. Liquid automated chlorine systems are more expensive and complex but don't add other chemicals to the pool which cause other problems.
gwegan said:
A several points.
Thanks, didn't realize 3 different manufacturers, will discuss with PB, also the rainbow chlorinator.
And there goes the yard! :mrgreen: Can't wait to see it completed!
