Constantly have debris in pool
Aug 10, 2013
4
This is our third season with this pool and it has been a very frustrating one! I have a constant amount of fine debris in the bottom of the pool. When I try and vacuum it out I can just see it coming back in through the jets after just a swipe or two.
The last two seasons I would see the jets stop flowing with a change in pressure and I knew it was time to backwash. This year they just keep flowing and you see a dark muck flow out of them. There is no change in pressure.
Specs:
31,000 gallon
Hayward Sand filter
Multi position Valve-don't know which one though
Pump motor and impellor were replaced last year
Sand was replaced in 2010 just before we purchased the house
Do I need to dump in a lot of clarifier?
Do I need to change out the sand?
Is there something to look for in the multi valve?
Pump motor was a direct replacement 2 hp. Don't know model type of pump as there is no labeling. Motor and impellor were replaced early last season and continued to operate as before. Debris problem started in early June of this season after pool had been opened for a month.
