CC level too high?
Ame
May 22, 2013
109
Phoenix Arizona
After SLAMMing my pool I have been slowly lowering My SWCG run time to reduce the FC It stabilized around 9 and now Im slowly lowering it. My question is My CC was at 1 sometimes 1.5 before and during SLAM. Now Its is consistantly at .5. Its been .5 for almost 2 weeks'ish. Is that ok? The water only has a pink'ish hue when I start the CC test, then after 1 drop :clear. The hue is so faint, I count it as .5=1x.5.
A lot of pools show .5 cc continually. As long as it doesn't go above that it's fine. If you really want to see what it is oyu can run the FC/CC test using a 25 ml sample. Then the drops are multiplied by .2 insead of .5.
