I am thinking about the BBB method but I have to use all this stuff I already bought
Maybe not.
OK, so here's how it turned out after draining.
I drained 1/3 of the pool the first day and it had very little effect on the cya.
I drained 2/3 of the water on the second day and the cya was finally measurable on my kit at 90ppm.
So if my math is correct I changed about 77% of the water in the pool and it is still sky high.
I chlorinated using cal-hypo and it only took 10 ounces to bring the TC to 5 so that's good. That is a big difference from 10lbs.
I am going to hold off from draining again until I see the bill for 20k gal of H2O.
Complete readings are as follows:
TC 4.5
FC 4.0
PH 7.4
TA 130
CH 120
CYA 85-90ppm can't really tell and I am waisting all my reagent second guessing myself cause I am a bit ocd.
So does this mean my alkalinity is actually low if my cya is still so high?
I don't remember the formula for figuring out what portion of you TA reading is the cya jacking it up.
What else am I still missing here? Should i just give it a break for a while and swim?
