Results 1 to 11 of 11
Thread: Lost Skimmer Sock
    Northeast PA
    29
    Lost Skimmer Sock
    Hi I have a 15' AG , Hayward Sand Filter S166T and Power Flo 1Hp pump. We needed to replace the skimmer and did it last evening so pool just used for first time this season. I put in a knee hi stocking and everything was fine. When i checked this AM the skimmer basket was upside down and no knee hi. Everything seems to be running ok, there is good pressure from return and into skimmer but it won't backwash very good and there is only 2 lbs pressure. I don't know what the pressure was last nite because the gauge was broken and just put the new one on this Am. Help.
    Thanks, Carolyn
    AG Pool 15 ft. round 4,000 gal. 100LB Hayward Sand Filter
    TF 100 Test Kit
    Carpe Diem!
    Mar 2007
    Texas
    441
    Re: Lost Skimmer Sock
    You may have gotten your knee high stuck in your 6-way (if you have a 6-way) valve. I would take it apart and see if the knee high is in there and has something "clogged" up.
    27' Round AG, 17,200 gallons, sand filter
    Northeast PA
    29
    I just checked that and it isn't there. But now i am seeing sand in the pool.
    TF 100 Test Kit
    Carpe Diem!
    Fayetteville, Arkansas
    220
    Did you check the final trap?
    20x40 30,000 gal IG Liner, Pentair II Sand
    Look in the pump strainer basket.
    Northeast PA
    29
    My pump doesn't have a strainer basket. What is the final trap?
    TF 100 Test Kit
    Carpe Diem!
    220
    Quote Originally Posted by car8857123
    I call it the final trap. Same as pump basket.
    Northeast PA
    29
    So what would be the next step?
    TF 100 Test Kit
    Carpe Diem!
    AnnaK's Avatar
    Jul 2007
    Eastern Pennsylvania
    1,132
    No strainer basket in front of the pump? I thought all pumps had one of those. Learn a new thing every day.
    At this point I would take the sand filter apart and dig through the sand. Once you find it and have everything put together again, if you decide to keep using the skimmer sock (which I highly recommend) put a rock in it. That will help hold the sock down and also keep the skimmer basket inside its housing when the pump is off.
    — AnnaK —
    12,000 gal AGP, Hayward sand filter, Pentair 2-speed pump, timer.
    Please visit our Pool Issues pages for information about step weights, managing the solar cover, and PoolSkim.
    Mar 2007
    Morris, IL
    477
    Well, if the sock is not in the pump, I have to wonder where it is. I think it went into the valve, and if it made it past that, then it is in the filter. So, does water go through the center tube, then out the laterals through the sand and back into the pool? If so, then maybe the sock is down in the center tube. If not, then the sock is on top of the sand. Another thing. I can't imagine how it would get past the pump. I bet it is twisted up inside there around the impeller. Not the basket area, there should be another hole leading into the actual pump between the basket and the motor.
    steve
    Above Ground / 18' Round / Vinyl Liner / Sand Filter / 100K Gas Heater / Salt Added / No Nature2
    Northeast PA
    29
    Thanks for the replies. Ex husband who's here everyday to see the kids took everything apart and sock was almost in the pump so we were lucky. Of course hes bit*****g me upside down. Since he never heard of skimmer sox and it wasn't his idea then it must be silly. Of course he does so much with the maintenance end of things that I couldn't do myself. (I'm the pool cleaner and chemical person). Just got my TF 100 kit, only took 2 days, yay can't wait to use it. Carolyn
    TF 100 Test Kit
    Carpe Diem!
