Raising a Hot Tub?
shltn
Jul 23, 2013
39
I'm in the process of re-working our backyard, adding a pool, etc. We have an existing hot tub that sits on a concrete slab. Once the pool is set this week we will be building a deck that ties the hot tub into the pool.
My question is: if needed, how should we go about raising the hot tub up (probably a couple inches) to meet the level of the pool deck? What would be needed underneath to support it properly?
Yes, it'll still be on the slab. I guess that was my main concern - does the raised base need to be a completely solid or can it be a frame on say 16" centers? I'm not sure if the tubs can support the water weight without a solid base.
