replace union
Hello - The union on my pump is leaking a good amount of water that i believe is affecting the pressure as well. What is the step by step process to replace this? i am pretty handy but this is my first attempt at replacing pool plumbing.
Also- you can see a coupling downstream of the pump. A specific question would be where is best to cut this pipe to replace the fittings? should i cut past the coupling or before it?
