Thread: booo,leaky sand filter
    May 2008
    upstate, SC
    29
    So my pools finally full and I notice i have goos leak coming from under the filter Since I cant see where its actually leaking I am gonna guess I lost a seal on the bottom.
    Can someone point in the right direction for getting a repair kit? Its a Tagelus TA-60 This pool is snowballing on me and I haven't even got to go for a swim yet
    18*36 oval
    TA-60 sandfilter
    Dec 2007
    Central New York
    504
    Re: booo,leaky sand filter
    Try here.
    http://www.poolcenter.com/parts_filter_ ... agelus.htm
    There could be other places on the internet.
    Could the leak be from the drain plug?
    Hotrod30
    20 X 40 foot vinyl Borates and Salt Pool
    Rolachem Chlorine Feeder
    Hayward 27 inch sand filter with 80 lbs of pea gravel
    Jacuzzi Splash Pak SP55 DE filter in parallel
    Pentair VF3050 pump
    May 2008
    upstate, SC
    29
    I dont think so, I don't see part #8 on the parts list? If part #8 goes through the bottom of the tank w/a seal like it appears in the drawing, most likely my leak is there, if it does not, then I guess i have a crack in the tank itself. Its just really tough to tell without cutting the pipes and lifting the tank So if anyone has any exp. with this, It will help a great bit!
    18*36 oval
    TA-60 sandfilter
