Polaris booster pump- quick connect broken off in pump intak
Re: Polaris booster pump- quick connect broken off in pump i
Jwood7 said:
How do I remove the broken piece of the quick connect from the pump intake. :(
I believe they make some type of spray you can spray on the similar to WD40. You could also try a two pair of channel locks if you have them. One on each side.
