Results 1 to 7 of 7
Thread: My little AGP was great until I put in PH PLUS
    Jul 2007
    Fareham,England
    41
    What have I done?
    I only have test strips but my PH according to the strips was 6.8 so I added what is called pH Plus(Label Sodium Carbonate)
    Instantly the pool went from blue sparkling water to cloudy white and horrible.
    What did I do wrong? Everything else seems to be fine apart from it being cloudy. I have now bought it up to shock level and it looks clearer until you move the water around then it goes cloudy again.
    Guest
    Post a full set of test results. I will bet that your calcium hardness is high and that you precitpitated out calcium carbonate, making the pool cloudy.
    THIS is why having a good test kit and good test results are important before adding chemicals!
    Jul 2007
    Fareham,England
    41
    I have spoken to Dave about getting a good test kit out in the UK.
    We only have test strips out here....
    Pools is the next big thing out here.. Just our weather. Rain sun rain more rain..
    Guest
    Quote Originally Posted by wampa1
    Palintest is available in the UK and they have a range of testkits for pools.
    Jul 2007
    Fareham,England
    41
    Re: My little AGP was great until I put in PH PLUS
    Iam at my wits end now. Pump running 24/7 Ok Intex pump, Pool clear looks crystal blue. Then you get in the pool less then 5 mins and the pool is white and cloudy & very gritty under foot.
    PH 7.2
    free Chrlonine 5
    total chlorine 4
    Total Hardness 400
    total alkalinty 130
    I do have a solar cover on when running the pump with skimmer attached(leave a gap for the skimmer to collect water), Could this be the Problem?
    When I didnt have the skimmer never had a problem... also never had low Ph before.
    You need to bring down your CH and/or TA levels. TA can be lowered with acid and aeration, see this Pool School article. CH can only be lowered by replacing water.
    Jul 2007
    Fareham,England
    41
    The pool has not been used for 14 days( still checking daily and putting in Chlorine) could this be the cause??? with solar cover on?
    Bad weather in the UK..
    Today loads of kids in the pool splashing!! Just gutted that they seem to be swimming in cloudy water..
    Less then 5 mins before it went cloudy, 4500 litres or is it just my pool is too small?
